Spring hanger bolt pattern
ChargerST
3:40 AM
Austria
Does anyone have the bolt pattern for the front spring hanger for a 68-70 Charger? I assume 66-70 B-body should all have the same pattern..
Thanks!
I don't have a pattern, but it is not rectangular. The spacing between the upper and lower holes is different as I found out trying to make some wheel stands for moving the body around without the rear end installed. I'm sure someone here will have the answer in a day or so.
Mancini's sells a stiffener plate for that area, with the right bolt pattern on it. Same pattern for early B-bodies as well.
I found the dimensions here - at least sort of as the picture resolutions is quite bad. I can read 1.5" and 1.75" distance between left and right but not how far apart upper and lower bolts are ..
@rbkt65 can you help?
please help identify these spring hangers
Great! That confirms the 1.5" and 1.75". Missing length is 3 3/8" then. Thank you!
