Torx WTF
I submit the following smart *** replies-all done in the voice of Gilbert Gottfried
1. And they have the nerve to call them TORQUES!
2. Dont even think about buying Harbor Freight Torx bits!
3. Remember the old shade tree torque rule of thumb- tighten till it breaks then back off 1/4 turn
Remove torx and use normality. Retain sanity. USA fasteners like good old days!
who came up with this crap?
my buddy was here working on his car....... alterkation front
anyway, bolts in aluminum hubs are T45 and call for 55 ft lbs of torque......he breaks a craftsman T45
no biggy, I hand him a Snapon T45 ........ and snap! WTF!!! :BangHead: :BangHead: :BangHead:
pic, as per the golden rule
Are you sure it's not a T47? There is that size used.
You mean slotted screws so that everyone with a rounded off flat screwdriver can really bugger up the screws?
The best and only screw I use by choice now (and for the past 10 years or more) is the square drive aka the Robertson screw. Almost 100% guaranteed not to slip or break.....except Stainless steel versions. I only use the SS square drive screws for soft applications - cedar or plastic etc....never in hard woods ....and I am very cautious when using them outdoors in concrete or brick.
They are so good you can even get the next size down driver, and they still undo without issues.
AKA Tamper Torx. For security - usually installed by Chinese manufacturers of toasters and kettles etc. Home appliances for preventing potential home repairs.
And crapper doors in Chrysler bathrooms to keep people from stealing the hardware, for what, lord only knows. :thumbsup:
My company uses button head cap bolts with hex head and they are always stripping out. Not only does a person need quality tools to do our jobs but they need to use quality fasteners
I used thousands of socket head capscrews, and many hundred button heads, in my business. Never had much problems with them stripping out. (Everything from 6-32bh to 1/2-13 capscrews.)
I did round out a few of the smaller Allen keys. I think the,bolts, even button heads were harder.
I like your first comment about flat screw drivers.
Another story, 1970 Myself, my wife, and brother-in-law drove our 1964 Custom 500 Ford to Glendive Montana for the drag races. Ran into a rear axle wheel bearing problem. After the races, someone suggested we go to this particular service station. We arrived two young guys thought they could fix it. I suggested that if they let me into the back I could do it or give them advice. No go. After an hour I asked if they could call the owner. He came down, turned out that one was his son. As he was working on the car, he noticed an interior car warmer screwed to the dash. Didn’t know what it was. Wanted to buy it. I said okay, then he wanted to know what those square headed screws were, so I told him, then he asked if I had the screwdriver I said yes. He wanted to buy everything because no one else would have one.
He was so pleased, he offered us a real deal on 4 tires that we couldn’t resist.
Since you have Robertson screws, do they turn in the same direction as the water drains heh heh??!!
These are in a high rust and corrosion area.
I wanted to give you a Thanks and a Like. :thumbsup:
Nice thing about square drive is sometimes they will work on a stripped Phillips head.
Torx and especially torx plus (or IP improved) are used on a lot of inserted cutting tools.
I have had to buy torque limited drivers for every size so my machine operators don’t destroy things on a regular basis.
I still use Premier Supertanium hex headed bolts for about everything. I use their files and they have the very best taps I have ever used. I can per drill for a 1/4 inch tap and run it through 1/4 inch steel in a variable speed drill. The company was bought out by Lawson years ago and I don't think they're still in business anymore. They were like ARP and I still have a bunch of the bolts in an assortment of sizes. When the plant closed they were thrown away with everything else and I took them home, by the bucket full. I'd been buying them for the plant for years and they were expensive as hell and strong. I put one car back together with nothing but them.
update........... my boy bought an entire set at Harbor Freight for 32 bucks, 55 ft lbs no problem ........ I was impressed
I had to torque a bunch of ARP fasteners today, and they were all 12 point. I had to dig around in my sockets, but luckily I had some.
I am installing a pressure plate, it has 3/8 studs with 7/16 12 point nuts. All of my sockets interfered on the stud, so I had to drill out the center of a 7/16 deep well socket.
