Tyron68
I’m gonna ask what is probably a dumb question. I’ve got all my brake lines installed/connected and now I’m down to bench bleeding my MC and connecting the lines to it. If the master cylinder has brake fluid in after you bench bleed it, how do you connect the remaining lines to the MC without fluid coming out of the ports? My MC is a Raybestsos (MC36283). It came with these three little plus that I am assuming are what I use to bleed it. Seems like when I take those out to put the actual lines in the fluid will just come out of the MC? It’s a front disc/rear drum 69 charger.
