Where's Waldo (or the MP B/RB single bolt timing gear set)?
PsyOps
4:28 AM
Pacific NW
I just unearthed a new Mopar Performance single bolt roller chain & sprocket set (P4120264) in perfect condition except for the 20-year collection of dust on the outside of the package. I went to check on what this was selling for and I can't find it. An interweb search turns up a couple references in engine builds but nobody (Summit, Jegs, etc.) has this for sale any longer. What's up with that?
All the old school MP stuff has been discontinued for years.
Ok. I knew some of it went away but not all of it - but you're probably right. I looked at "The Official Mopar Parts" site and their parts search by model year doesn't start until 1984. Now I really feel old...
mancini use to carry them ,thats here i got the last couple i bought (years ago) .
I hear ya. I just checked and Mancini only has MRE, Comp & an Edelbrock. I'm guessing everything is going toward the Gen III stuff.
Also alot of "authorised" is made in China now.
Newer, better products came out. Instead of drilling a hole and using offset bushings to degree a cam, you just turn the crank gear to a different notch. Much easier. FYI - I’m running one of those Direct Connection Stimming chains now
Mopar Performance were Good parts, last forever.
I agree. The original MP/DC stuff was top of the line for a long while - probably not as much now most of it is offshore as HALIFAXHOPS noted.
Easier yes, but better, maybe not depending on where you get it. A nine-way crank sprocket isn't better if it is made from crap metal (Chineseium) that will cause a timing issue down the road (literally). I was raised on the MP/DC stuff and will take those old NOS parts before considering Brand X offerings. I will say some of the top of the line (i.e. spendy) timing chain & gear sets have a fairly good reputation but my pockets aren't deep enough these days. I'd really like to find a 3-bolt cam sprocket for the above chain & crank sprocket. Maybe a want ad when I get closer to needing it?
So I thought about doing a wanted ad for a MP 3-bolt cam gear but realized that probably wouldn't get me what I wanted. A new idea has taken hold - having the 1-bolt sprocket drilled for a 3-bolt cam. Is this feasible or are there things preventing a skilled machinist from drilling those holes? The last resort is to sell this one and buy a Brand X 3-bolt set. Any experience of which ones to concider/avoid?
Take a look at Summit for high end billet timing sets if you're worried about quality.
They offer several options.
Thank you. I'm building a parts order with them as we speak and will add a timing chain set. I really don't think I'll need a 9-way crank sprocket but it might be good to have one of them "just in case."
You may want to make sure you can get the cam you need first. I had a tough time finding a 3 bolt cam on the shelf.
Thank you. I have a cam in hand. Just gathering the final pieces to build the engine when it comes back from the machine shop.
