dfrazz
No rubbing at all. Fonts are 215/70/15.That looks great. Any problem with tires rubbing the wheel wells over bumps? What size tires are you running on the front?
That's a lot of tire for a stock wheelwell. Did you have to remove the hump on the inside of the outer wells?View attachment 1849680
295/65R15 in back with 235/70R15 fronts. I don’t believe anything larger will fit without mini tubs and spring relocation…
