Random picture thread
Getting close to getting out of here! Even got it right the first time, stops in the correct spot for a hand swing...
Easiest way to check prop tracking on a float plane while snugging bolts. You can move the tips over 3/16" just on the order you tighten bolts.
3/8th bolts... get 220 INCH pounds. 18 ft-lbs.
Two quick test runs and stops in the right place both times! I get lucky once in awhile...
