Damaged power steering pump pulley.
chrger1967
5:26 PM
Where can I find a power steering pump with the pulley that fits my 67 Charger with a 383? I tried the Borgeson 800338 unit. It fit nice, without the spacers anyway, and I could finagle the hard line to work, but the return line on the pump they sent me will not fit between the fitting and the engine block, there just isn't enough room. I don't need that hose to be getting hot or rubbing on the block. Let me know if anyone had the same problem.
I put that pump in my car. I had to chip away at a bump on the block that was threaded. I really still need to take a little more off. The return line robs up against that spot when tightening or loosening the pump. The original pump had a damaged pulley and was making noise. The new pump is nice and quiet but haven't been able to test is with the wheels on the ground as of yet. Im just worried about the pulley being 2" bigger, I'm hoping Berguson was right in what they told me.
