Six Pack Stalling on hard braking
1968rt
9:44 AM
New York
440 six pack starts right up, idles great but has been stalling on hard braking. Im guessing float height or vacuum loss from power booster. What do you guys think? Mild motor .528 cam, 4 speed, 3:54 around 500HP.
Vacuum leak is my first guess
this is my guess, too. I resolved a similar leak in a 440-4 car by connecting and watching a vacuum gauge during normal driving, coasting and braking. I did not want to poke a hole through the firewall for the vacuum line (to read the gauge within the cabin) so I zip-tied the gauge to the wiper arm. After a few days of seeing the issue and fiddling around, I found the vacuum leak, which turned out to be the lower (carburetor) flange gasket with the intake.
Center carb float level too high.......I run mine with fuel level JUST BELOW SIGHT PLUG OPENING......no dribbling....front/rear carbs JUST AT FUEL LEVEL SIGHT PLUG........IT IS NOT A VACUUM LEAK.......just my opinion......
BOB RENTON
Well I guess I will start with the float, then add some timing, then check for a leak. What a pain!!
Best way to check for a vacuum leak is to spray carburetor cleaner around the base of the carburetors and intake, then go from there.
I checked the manifold and carbs, they are fine. I suspect the booster though.
why do you suspect booster?
Was this a non-issue before on hard braking and now suddenly it is or is this a new or tuned carb setup and suddenly the issue started? When I first installed my Quickfuel 735 SS on my 451, I had the same hard braking stall problem. I lowered the fuel float level to bottom of sight glass and the issue went away.
Under hard braking, my 440 w/850 Demon would almost stall after panic stop. Only one time. Leaving a 4way stop, Linda screams THEY DONT STOP! Guess what, they DO stop. One other time, I “saved it. Try not to brake hard unless urgent.
Well I had a mother of a time getting these carbs right. Drilled out the idle screws on the end carbs and finally got the mixture right. Then I had a slight vacuum leak, which turned out to be at the base plates. Problem now is that the car was laid up for a year and a half. I lost two close members of my family so the car sat. This is the first time since Feb 2024 that it ran. Maybe I need to check the needle in the center carb also. Could be old gas crap in there also! Never trusted the repo booster. The brakes just didnt feel 100% right.
My guess would be float levels too high on center carb too
if not
maybe it's a cracked/split or leaking hose, vacuum leak
could be a carb base gasket too
Are the fuel baffles in place? Top of the metering block..
Or the better design, known as a whistle...
And the hotrodders fix when both of the original Holley designs fail.... is a vent tube extension...
The one shown is the fancy pants version... Usually just a length of 5/16 hose to raise the vent higher prevents fuel sloshing out of the vents which causes the stumble/dying...
GEEZ Linda...
Dennis, I can hear your voice now as you explain this. Too funny - I'm laughing out loud now.
The carb bowls are front mounted so on hard braking, if it’s the carbs the fuel is stacking up forward starving the jets. The solution to that is raising the float level slightly or installing jet extensions. Fuel bowl baffles and flooding from a hard stop should not be a factor on six pack carbs.
However, the vacuum brake booster also is a good possibility. Could be as little as a bad vacuum check valve.
This is NOT a vent problem. Look how far the fuel has to rise in the vent tube before it can exit & go down the t/bore into the engine. It is most likely low fuel level...fuel uncovers the jets.
Jet extensions would be a good idea.
It could be excessively high fuel level also. On hard braking, the fuel slams into the front of the float bowl...& then a reverse 'wave' comes back to hit the met block. The fuel rises in the emulsion tube well, high enough to enter the booster & flood the engine.
I had the same problem some time ago. Running a six pack setup on a 493 stroker, with a 528 solid cam. The engine would go lean and try to stall upon hard braking, especially headed downhill. See below for a reprint of my old post:
On the subject of fuel slosh, I found that the reason for this behavior was the center carb metering block. Here goes:
I had noticed that my steady state cruise AFR was rich, so I popped for one of the Promax metering blocks for the center carburetor. My intent was to reduce the area of the idle feed restrictor (IFR); this orofice controls the amount of air/fuel emulsion that reaches the transfer slots. Note that the idle mixture screws are upstream of this restriction, so they do not affect the transfer slot operation. The metering blocks arrived with the IFR's installed near the top of the metering block, well above the fuel level. Older Holleys have these installed at the bottom of the fuel well, below the fuel level. I had read that many folks prefer this configuration, so I moved the restrictors to existing locations at the bottom of the fuel well. Note I had to deepen the threads on these holes to seat the screw-in restrictors correctly. I also experimented with reducing the size of the IFR's, drilling out some 6/32 hex brass setscrews. The IFR's that came with the Promax plates were 0.031" diameter; I replaced these with 0.027" restrictors.
The result was a leaner cruise AFR (~13.8 or so), and I noticed the "fuel slosh" problem was gone. As detailed above, I had previously noticed that deceleration/mild braking, especially facing downhill, would lean out the idle AFR to 16-17 and change the tone of the idle as well. My concern was that the engine might stall if I really needed to brake. This behavior virtually disappeared with the reworked Promax metering block, but why? Well I can't say I understand why, but I had noticed that the stock Holley metering block uses a pressed-in tube in the idle well. The low end of this tube serves as the idle feed restrictor. Note this carburetor is a new generation Holley, not an OEM sixpack carb. The upshot is that there appears to be some dynamic fuel level behavior in the idle fuel well that is much more pronounced with the "new" idle well design.
Hope this might help somebody who has seen the same (mis)behavior with the repro six pack setup.
