FOR SALE Hemi Motor Mounts
SSing
5:17 AM
Feedback: 2 / 0 / 0
Really nice K-frame brackets, if you want to build your own Hemi K-member.
These are very good copies of the B-body type brackets, also used in the ´68 A-body and can of cause be used in any car model.
Shown is an A-body K-member and I have the instructions if you need them to get it right.
If you made a request earlies price is $450,00
New price is $495.00 + shipping ca $50-60 from Sweden.
Thank you.
Will these work for an E body? If not, what's the difference?
Actually I think yes, if you cut the top off of this bracket (driver side) and use the ´71 B-body/E-body rubber mount (Mega Parts) Than drill a new hole to fit this E-body rubber mount.
As for the passanger side, I think they are all alike, exept there may be a bigger gap, or you may to do some trimming to make this weld on bracket fit good to the K-member.
Also important of cause to place the block correct in the engine compartment.
This I don´t know for the E-body but suppose 1,2" offset and some 6" center of crank from K-member, like the A-body was done...
Find a E-body rubber mount an see if it fits.
