Lloyd Hammond
- 3:21 AM
- Jul 3, 2021
- Fremantle, Western Australia
Hi, Never having rebuilt one of these before, I bought a kit and disassembled the unit. It was leaking from the main body seal. That seal was rock hard and square. Also found other seals needed replacing. It had a good clean and I reassembled it. Only problem is, I disassembled the pressure relief valve (followed a youtube - that was really bad). The guy pulled the pump apart, cleaned the relief valve and screwed it back together. I cleaned it out and then screwed it up, not realising that it was a 'factory set'. How do I reset it? Just go half way?
On a separate issue, the flow control valve was very tight in its bore. I had to lightly tap it out with a small drift. Is that normal?
My pump looks idential to the one in the pic below.
Cheers.
Cheers.
