- 11:11 PM
- Jan 30, 2010
- South Central Ontario
Anyone know the noticeable difference between a 69 Charger ralley dash ash tray vs 69 Road Runner non ralley dash ash tray ?
does the above apply to 70 rallye dash ashtraysVery slight difference in rallye vs. non rallye. If you look very close you will see on rallye there is a very slight witness line in center of part top to bottom. Two angled surfaces meet in center of ashtray. The non rallye ashtray is a single flat surface. You may need to put one side by side to see the difference.
Compare the actual ash receptacle size you will see a difference is shape and size between the two if you have a rallye and non rallye.Heres the two I have side by side. The black one from a 68 Charger, the gold one from a standard dash 69 Coronet. I see the faint line in the middle on both. My green 68 Charger ash tray is the same as these two. I dont know what to think anymore.
Your pictures appear to show two 68-69 rallye (blue & tan) and one 70 rallye (black). I do not think any of these three are 68-69 non rallye.I've been following along as I have extra ashtrays.
They are all the same width, and the 68, 69 rally, non rally, interchange between each other and all hinge mounts.
So what am I missing?
