1966 Coronet Horn help
jteck10
6:33 AM
SF, Bay Area
well, im finally trying to fix all the small things on the car since shes running fine
one thing that has been bothering my is the horn not working
i think im missing a few peices or need to replace a few pieces for the horn, as its all old and cruddy
i'm not sure what all i need to get this done and cant find it on this forum
any help is greatly appreciated in getting my horn working again
parts i think i need :
- horn relay
- horn switch (circle in steering column)
- horn signal switch
- horn cap retainer
None of those parts pictured will keep the horn from not working. Start by running a jumper from a good ground to that black wire and see if you hear anything.
just tried this and nothing happened. i may try to replace the fuse first and see if that helps
i guess it would help if i even had a horn relay, eh?
just went to go look for it and its not there
i'll order that and wire it up and go from there
Horn relay should be on firewall beside driver's side cylinder head. That spot and wires in the picture looks like where the horns are mounted. I have a 66 500 if you want any pics or wire colors.
