- 7:54 PM
- Apr 13, 2012
- Granite Bay CA
For over 23 years, I've been a slave to the high cost of Premium fuel when I buy gas for this car...
The first 440 was built and swapped in the summer of 2001. It was iron headed and around 9.2 to 1. I ran Premium 92 then...
When the octane dropped to 91, I don't know if I noticed a difference. I built another 440 in 2004, this one with 9.5 compression and aluminum heads but still ran Premium 91. That mill threw a rod at around 850 miles so I got another 440 block and got a 4.15" stroke assembly to get 493 cubes. I was now at 10.8 to 1 and still needed Premium fuel.
Over the years I've dealt with detonation. I've tried delaying spark advance, limiting the advance, making sure I wasn't running lean, bigger cam, thicker head gaskets, higher octane fuel like so:
In 2022, I pulled the engine to go through it after a camshaft went bad and ate several lifters. I took this opportunity to lower the compression a bit but add quench.
I'm now at 9.8 to 1 but I have a quench distance of .040. I've been careful and have kept using 91 octane fuel at every stop...until May of this year.
On the way home from a car show weekend in Van Nuys, the group I was with stopped for gas just off the freeway. Just for the heck of it, I topped off with 89 octane mid grade.
Now, I still run 35 degrees of total timing which is in around 2500 rpms. The engine did not knock at any time but just to make sure, the next fill up I tried 89 octane again.
Still no knock and no run on when I shut it down. It has me wondering if I could actually run it on 89 octane.
I've been careful to always run the highest grade gas for years so being able to get away with cheaper fuel in the lower octane is great! I don't mind paying for the better gas in this car since the car is not a daily driver.
Still, if I can save 20 cents a gallon, that is cool. Also, it is nice to feel okay if I stop at a gas station that only has 87 and 89 octane.
What is the highest compression ratio that you have ran on regular or mid grade gasoline?
