Dibbons
- 4:02 AM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
Is nothing at all just simple, cut & dry these days? Rather than change the oil at the regular quickie shop I frequent (where they always over-tighten the oil filters) I purchased some motor oil at Sam's Club (store brand) for one of our two Jeep Cherokee XJ's.
Brought a breaker bar and a variety of sockets (did not want to fight with a real tight drain plug) and crawled under the vehicle along with a drain pan. At first I found a 9/16" socket too small and a 5/8" socket too bit. Finally, I was able to force fit the 9/16" on (found out later the head of the drain plug bolt was covered in silicone which caused the confusion).
Well, I didn't need the breaker bar after all, although I used it. The drain plug seemed not tight at all. Was almost thankful for that discovery until I spun the plug over and over again and it made no progress in coming out (found out the threads on the plug are almost completely smooth/stripped).
Now had to put on my thinking cap on how to remove the stubborn drain plug. Gathered up a pair of flat bladed screwdrivers and a pair of vice grips. I then proceeded to pull and twist at the same time with the vice grips while simultaneously prying under the head of the drain plug with one of the screwdrivers. Finally, it started out and I grabbed it before it fell into the pan. I'm going to call it a day now and just tell my story to whoever will listen.
