Oil Pan aluminium mopar big block 383 440
thcmaly
12:08 AM
Ilinois
Hello, does anyone know what kind of oil pan this is? It's aluminum and fits Mopar big block 383 400 440 426 engines. Casting number CCP 2659266.
Cześć, czy ktoś wie, co to za miska olejowa? Jest aluminiowa i pasuje do silników Mopar Big Block 383, 400, 440 i 426. Numer odlewu CCP 2659266.
You need to translate this into the English language. Otherwise, it's unlikely you will receive any answers.
Hi, does anyone know what this sump is? It is aluminum and fits engines. It is some odd ball industrial application. Like a generator or water pump.
Similar, almost identical, but mine has additional holes in the back and a tube sticking out on one side.
Probably different applications. Who knows. Not worth anything for an automotive application.
I'm curious if it applies to Dodge Charger, Plymouth and Chrysler cars with a K-frame.
I have the oil pick up for that marine pan.
It is a swivel type that is similar to the early Max Wedge engines used.
I figure it so the pick up stays in the oil during acceleration and when stopping.
