j-c-c-62
So, is asbestos still used?
Found this out the real hard way in 2009. Replaced a leaking seal on a 351C. (I know, it’s not a mopar.).Modern rope seals aren't made of asbestos and don't survive as well as the originals did... In the past you could find NOS rope seals still in the Mopar package on Ebay... If I were building an engine that would be my preferred route..
But Asbestos causes cancer.... Excuse me? Last I checked once in place no one is handling a rear main seal.. Just wear latex gloves while installing it & remember not to eat the ends that get cut off during the install & you'll be fine...Found this out the real hard way in 2009. Replaced a leaking seal on a 351C. (I know, it’s not a mopar.).
Replaced the original seal when refreshing the engine and doing a clutch upgrade. At first good but oil leakage went to 2 quarts per thousand miles in short order.
When I dropped the pan, in the truck btw, and pulled the seal again, the seal looked like a half filled sock. Scrounged up a vintage seal and installed. 15 years later, no weep or oil loss.
Time may march on but newer materials and technology does not always mean better.
