Cheap Parts Quality Question
Mariposa Mike
11:11 PM
Mariposa, CA
Going thru the brakes on my 66 Charger I found that one front drum was turned beyond legal limits (.120 thousand) of .090 thousand inch. The other front drum is turned about .020. I have pulling to the right on the better drum. It has been replaced and the other has not. So...looking to replace the bad drum to maybe eliminate the pulling issue which I was not able to do with adjustment. When looking at prices for 10" drums on line I see a great difference in price and brand selection. NAPA has a couple at $164 and $227. Checking with Rock Auto they show two much cheaper. AC Delco $35 and Raybestos $37. I have all new shoes/cylinders and brake lines so the shoes are not arced in to better fit the worn drum yet. I figure now is the time to change that drum or both front drums to make sure I have equal braking.
Can these cheaper drums be anywhere as good as the expensive ones? Interchange numbers listed are different and I do not know what the original MOPAR number is for my car. The ACDelco lists an OEM interchange for 19176960. The other has numerous numbers beginning with 0, 2 and 3.
Specs listed appear to be correct. Other than paying additional for shipping these would be much less expensive than the NAPA products but those might be made in China as well. The NAPA drums show a balance weight on the drum for the cheaper one and no weight on the $227 drum but also no country of origin.
Has anyone used the Raybestos or NAPA gold? And are the cheaper ones the way to go?
I used a cheap set of 11-inchers from China and while they were machined for a smooth, round, braking surface..... they were not cut centric to the hub. How they made them this way I cannot fathom. It took a bit of head scratching to figure out why I was getting a pulse at the pedal. I was able to have them corrected on a brake lathe (at my expense). So.... I will not be buying cheap drums any more.
IF you have someone locally that has the machine and the know-how to still turn drums..... I'd buy the cheapies and plan to have them tuned up.
Brake parts simply can't be complete garbage, or the lawsuits would be epic!
And I agree with Threewood!
The Delco drum "looks" more like the remaining original except no outer spring around the drum but in the description it mentions they follow the OE design making them the ideal premium aftermarket replacement for your GM or non-GM vehicle. AC Delco 18B2 for anyone who wants to see the picture and description. I now know many of the drum brake parts were standard for other brands but not sure about these.
Ac Delco used to be top quality replacement parts.
Probably not anymore, but then again they might be just fine.
How about @mobileparts
I always ask my self the opposite, can these expensive parts be better than the cheaper parts?
The answer always seems to be more expensive is just that.
Finding old parts and/or parts cars has become my first attempt.
Do yourself a favor. A big favor. Contact Craig at mobileparts. He's here in this site. See post #7
I sent a private message to mobilparts but have not heard back. I need to move on so unless someone knows a better way to contact him I will have to go with what info I have. Thanks to those who responded.
Even 50+ years ago, it you installed new drums on a old hub and staked them properly, you still needed to true them up on a brake lathe.
Always replace front drums in pairs. They should have the same amount of material left or the thinner one will most likely cause a pulling problem when hot.
One f many reasons that drum brakes are no longer used on the front of passenger cars.
I agree they should be replaced in pairs but my one good drum is a replacement and have very little wear. Going to take a chance and try it along with one coming from Rock Auto. The NAPA drums shown on line were not available when I called to ask who made them. I'll advise if it's an issue with being true or with putting the old hub on it.
They’re all Chinese unless new old stock,don’t expect them to be round either. Unless you’re road racing,get some old real brake shoes from Craig. Leave him a message,he’ll call you back unless he’s dead! I went through the gray lining new shoes ,noisy,dusty,in the trash.
The one I got from Rock Auto was a Raybestos product. No indication where it was made but seems to fit well. Still have a slight pull but the shoes are still breaking in and a final adjustment will be made once they arc themselves. Nice to have all four drums working. Tried Craig but did not get a response. Well I got one but it was critical of my posts rather than helpful. Would rather have OEM but this car is not being driven daily. Mainly to shows, coffee and cars or pleasure driving in sparse traffic. Hoping these work out and don't squeak.
