FOUND 1966 Dodge Coronet, 2 – door Sedan, OEM windshield upper inside trim clips
LSS&B
9:07 PM
Aylett, VA
Feedback: +0 / =0 / -0
I want to buy these OEM clips because I need to install a new windshield in my 1966 Coronet 2 door sedan. Before I do so, I need to set up clips for the inside upper trim to screw into. I borrowed the 1st 3 pics from member @dadsbee in another thread.
*I bought the car with badly cracked windshield and inner/outer trim already removed. I disposed of the cracked windshield. Original clips are MIA.
*Mega Parts is out if stock and apparently the aftermarket clips are junk anyway. Headliner Clip Set (at Top of Windshield) 1968-70 B-Body, Interior Trim Clips, 132-1602020 Reproduction, NOS and Used Mopar Muscle Car Parts
beerestoration2017 1074.JPGbeerestoration2017 1171.JPGheadlinertrimclips.jpg
My 1966 Coronet. 1st pic is primered trim. Other 3 are windshield frame.
If anyone has pictures showing how to install this trim piece in a 1966-67 Coronet/Satellite, I would really appreciate seeing the pictures. Thanks, Ben
20250801_170833 Upper windshield trim, inside.jpg20250803_115121.jpg20250804_151639.jpg20250804_151709.jpg
I bought some from Stephen’s preformance. On a side note, I ended up putting a 1/4 in aluminum pop rivet in some of them to hold them in place. Once the headliner is installed they are not visible
If I go to a junkyard, can they be removed without removing the windshield?
If so, is best method to pry them out with 2 flat blad screw drivers?
Do you have any pictures during installation?
