1968 Dodge Charger Wiring
Charger Too
6:39 AM
Illinois
I need all of the wiring for my 1968 Dodge Charger. Who is the best vendor to use? Thanks!
Year One, mega parts, classic industries…doesn’t matter, they all sell the same damn harness. Year One used to be the exclusive dealer of M&H factory wiring harnesses.
Just double or even triple check everything to make sure it’s correct as you install it.
And also note. The harnesses are all just the base harness. There’s no a/c, tach, map light, dome light, trunk light, console wiring or any other “additional” wiring supplied with them.
I bought all my M&H wiring from Year One.
As Black 68 noted you will need all the accessory wiring he listed. So save all your old acc. wiring to transfer over if you’re not buying new.
Also the harness from drivers kick panel to under drivers seat to console is not made by M&H. I believe a member here found one at Parts Hound- not sure.
Get a manual for the wiring diagrams, you will definitely need it.
