68 Coronet that is back feeding voltage?
Smitty68
2:58 AM
Buffalo, New York
Hello Everyone,
This is my first post, and I did try to search to see if anyone else posted about this. I have a '68 Coronet that is doing something that I have not seen before. I had a parasitic drain that I found was caused by an aftermarket security system. I removed the security system and the drain issue was resolved. Now I have approximately 0.15mA from the removed negative cable to the negative battery post, which is fine, but I am reading 12.7VDC at the same spot. (Negative battery post to the removed negative cable). Any help will be greatly appreciated. Thank you!
In my opinion you still have a drain. Start at the fuse box and remove one fuse at a time until there is 0 draw. By the way go to the Welcome Wagon and introduce yourself and car and post some pictures of your project.
Thank you for your response.
Hello Everyone,
Connecting the meter leads between the disconnected cable and the battery post is putting the meter inline in the circuit. This is basically just testing voltage "potential" at the point of the open in the circuit. So a battery voltage reading is normal for how you connected the meter in the circuit.
This is true only if there is at least one circuit With continuity (except for ground)
Possibilities include:
Aftermarket radio memory wire
Clock
Door open?
But .15 ma is essentially nothing it would take a month or more to drain your battery
A test light or amp meter, should be used to track down a significant ignition off draw. As stated above,a volt meter won't tell you how much of a draw it is.
Thank you!
