Wiring OER tic toc tac with Evans harness
Bleep Bleep
7:01 PM
Pittsburgh
Car originally came with only the clock. The OER ttt unit is installed. I have the harness from Bill but really unsure now of proper connection points? Are all or only some of the harness connections used?
Is there a Mopar Wiring for Dummies manual? Appreciate any direction guys!
this
It would help to know which model and year Simca you are working on. The tach feed from the coil is a separate wire not made with any harnesses.
To be clear, you’re saying for my make model the Evans harness doesn’t have a needed wire to the coil, and the Mega Parts harness is what I need instead? Correct?
The original Chargers all had the tach wiring in the harness. They all had tachs. After that I guess they watered them down to optional tach? Interesting
It sounds plausible with the 70, they came out with the XH cars.
I posted the wrong picture sample to the original post. See the actual one I got from Evans.
(FYI I did get the info on connection points so good there now)
The correct pictured Evans harness includes a separate gray w/black stripe coil wire to be cut to length and connected with a female spade connector that plugs into the harness’s pigtail fed through the firewall on the engine bay side.
