Big Block Valve Cover ID
matthon
2:36 PM
New York
Need help identifying the year/make/model.
First set, both have plug wire brackets on top/back and inner/side, with heater hose bracket on one.
Second set, one has plug wire brackets on the back/side and the middle/side, only, and has the heater hose bracket.
The other has no plug wire brackets, no brackets at all.
Third set, one has plug wire brackets on the back/side and the middle/side, only.
Neither has the heater hose bracket.
#1-2 1967 440 magnum GTX type
#3 1969 440 HP b-body
#1 is definitely 67 440 GTX
#2 looks 67 GTX, but could possibly be 68 A body.
#3 I have to agree with @R413
#1 I believe it is 67-69 a-body. The plug wire brackets on the top/back are to bring the wire over the cover as it cannot fit behind it.
Thought it was also GTX, not sure.
I found a video of a 'survivor' 67 GTX, they barely show the engine, you can just barely see the plug wire bracket on the top/back of the driver side cover with the wire not in it going around the cover.
2 & 3 not sure.
my 68 GTX had chrome covers on it when I bought it in 85, I assumed original; but cannot verify, maybe not?........build date 10/24........I'll get a pic
Are the rear wire brackets on the top or side?
Passenger can't tell, driver too fuzzy.
67 and 68 big block a-body cars came with "Chrome-plated cylinder head covers, oil filler cap and crankcase vent cap."
69 did not, no mention of them anyway.
Took pics of a 64 Street Wedge.
Original owner car.
Both valve covers have nothing on them, no plug wire brackets, no electrical brackets, no heater hose brackets.
So the second set I have has the same driver side valve cover.
I thought this would be more straightforward.
my engine compartment was bone stock...... car did appear to have a 5/68 warranty block..... what are these?
Appear to be 67 valve covers, but it's a early build date so they're possibly original.
