68n69 Charger
Good afternoon,
I am at whit's end on my brake installation on my restoration project. Started from scratch with a LEED Brake front disc brakes and drums in the rear.
Here are my questions/comments:
-My kit is a LEED Brake Kit FC2002-8405.
It has been so long since I have purchased the kit, I am not sure who I bought it from...ugh
-The master cylinder is a two bowl and different size outlets
-The kit came with a distribution block, that seems to be different than stock, that is not part of LEEDS kit. image below
-The LEED Brake kit came with a proportioning valve
-All new brake lines. I'll never buy stainless steel brake lines again! What a PITA flaring! It was like a sprinkler system going off when I first started pumping the brakes!
ISSUE(s):
1. I cannot get fluid to the rear drum brakes. I did get fluid at one time, but I used a vacuum pump to get fluid. I do not get fluid using gravity bleeding nor pedal pumping.
2. I can fully bleed the front disc brakes and had no air in the lines
3. I have checked the position of the "piston" inside of the distribution block and it does not appear to be off center, thus cutting off fluid to the rear drums.
4. I have checked for obstructions between the distribution block and the rear drums. Air flowed freely through the lines, including the proportioning valve.
QUESTIONS:
1. Does it matter what line (front/rear) is connected to the front bowl or the rear bowl on the MC? If it does matter, is the rear brake line to be connected to the front bowl? Or vise versa? I made new end connections, so it is possible that I them different than what the kit came with.
If it does matter, can someone explain why it matters?
I thought the front bowl and the rear bowl are connected internally, but I'm not positive about that.
Thanks to everyone that takes time to answer questions from folks like me! Getting closer every weekend
ISSUE(s):
QUESTIONS:
