Looking for Milwaukee area performance Torqueflites builder
Brewzer67
10:40 AM
Menomonee Falls, WI
I was forced to downshift to neutral while at freeway speed a short while back with a Cope reverse manual valve body with low band apply and want someone to do a once over to make sure the sprag and everything else looks ok yet. The former shop I used made some suspicious comments last time they rebuilt it for me so I'm not comfortable going back. They also had to readjust line pressure settings when I picked it up because they hadn't thoroughly checked everything. I have a billet drum and all the usual heavy duty parts so I want someone who is really familiar with what it should be set up like. It sits behind my strongly built 526" RB, so it needs to be right.
Any suggestions?
I would recommend Keith Long (727 Specialist) His transmission is behind the 512 in my wife’s Runner (640 lbft). Reverse manual billet and so forth. Works wonderfully! By the way, I suppose you wouldn’t consider him local but you’re a lot closer to him than I am…
Thanks but that is a bit of a haul from my area. I'm looking for someone a little closer.
No luck with the Jerry Quaden suggestion as the number is no longer in service. Anyone else have any suggestions?
Jerry is your man. He just did my 727 last month. Very pleased with his work! Great person.
