Dakar Timm
- 10:01 PM
- Nov 14, 2020
- Lake Mills Wisconsin
Two weeks ago I finished welding new floorboards in the Coronet . I thought I was finished after undercoating , installing a layer of sound proofing and new carpet .
When I started up the car to drive it down off the ramps , the throttle cable snapped .
I made a throttle cable from an old Honda motorcycle work well enough to move the car into its place in the other garage .
Once parked , I opened the hood to hook up the battery tender . Imagine my surprise when I saw fairly large stream of bight green coolant running down the front of the engine .
Back into the garage it went . I found the aluminum timing cover had disintegrated over the last 58 years . Geez , you’d think stuff would last .
As I was cleaning the front of the block for the new gasket I dropped a scraper and somehow it magically went into the oil pan ! Off came the starter , centerline , oil filter and finally the pan . Nothing else can go wrong can it ?
