63 Max wedge 3447 original jet sizes
bobs63wagon
10:41 PM
Minnesota
Anyone know the original primary and secondary jet sizes and metering rod number on the 3447's. Want to help someone out to put them on a 63 Max Wedge street car. At least a good starting point. Thanks for any help.
From the service bulletin for July 17, 1962 I have the following for #3705-S Carter AFBs:
Primary main jets: .104" (120-161)
Secondary main jets: Throttle lever side: .089" (120-159)
Choke lever side: .063" (120-176)
Step-up rods: Standard .066" X .053" (16-76)
Float setting; 7/32"
I'll keep looking for the 3447s... FOUND IT! LOOK BELOW
Found the information for 3447s AFBs:
Primary main jets: .098" (120-163)
Secondary main jets: .082" (120-158)
Step-up rods: Standard .068" x .050" (16-51)
Float setting: 7/32"
Float drop: 3/4"
Accelerator pump setting: (top of plunger to airhorn) 7/16
Idle mixture setting: both screws open 1-1.5 turns
THANKS TO DARRELL DAVIS' 1963 PLYMOUTH SUPER STOCK GUIDE BOOK
On the Dyno in our 3447 carbs we ended up with a 76 on the short
runner and a 89 on the long runner. Way different length on the runners.
This is with a production 63 Manifold. The A&A replacement made significantly
more HP and required a bit different jetting. i assume you still have the original
on your wagon.
Let me know if I can be of any help!
I wonder if the 098 pri jet is a misprint. The 3447 carbs had the small 1 7/16" pri bores [ versus 1 11/16" for the 3705 carb ]. 1 7/16" pri bore carbs generally had 089 pri jets.
Float drop: 3/4"
Thank you for the info and for taking the time to do it.
I did see one other place that said 089 primary jets. Thanks.
on your wagon.
I ran the 3447's for awhile but went to the Edelbrock replacement. Never run those on the dyno but will with the new motor. Having my headers fixed for O2 sensors on the dyno this time. Always appreciate your help John.
I will see my Friend Steve Wann next week at Bakersfield
double Divisionals. He is absolutely hands down the fastest
Max Wedge Racer currently racing anywhere. Hopefully he might
tell me a baseline setting for the Edelbrock carbs. These carbs were
not legal when I raced these cars.
I do not think these carbs are any better than the originals (Not
sure even nearly as good), but they are surely easier and way cheaper
to find. The issue with the original Max Wedge carbs is most guy run a
ton of return spring pressure on them and it really wears out the throttle
shafts.
He builds the carbs for a lot of the fastest Max Wedge Racecars
in the country and a lot of the turnkey race engines in for them
as well.
From the Old Mopar performance bible.
1964, 426 Max Wedge Cross-Ram Fresh Air
Carb:Two Carter AFB 3705S carburetors
Manifold:Stock Max Wedge Cross-Ram
Manifold Modifications:one
Carb Specifications:Two Carter AFB 3705S carburetors
Left Carburetor​
Throttle Side
Diaphram Side
Primary Jet:
120-410 (.110")​
120-410 (.110")​
Secondary Jet:
120-392 (.092")​
120-392 (.092")​
Metering Rods:
PT
WOT
16-76 (.066"x.053")
Right Carburetor​
Throttle Side
Diaphram Side
Primary Jet:
120-407 (.107")​
120-407 (.107")​
Secondary Jet:
120-389 (.089")​
120-365 (.065")​
Metering Rods:
PT
WOT
16-76 (.066"x.053")
Note: Same jets used for increased interconnection manifold (10 in.2 and 55 in.1). See Figure D.
Air Cleaner:Ideal Entry
Special Note: The modified interconnection manifold shown in Figure D has not been proven to be better than standard. Also, it has not been run on the dynamometer to revise the above carb specifications. On the 1964 Max Wedge, the increased interconnection does not appear to be a performance improvement.
GTX John.
Couple of thoughts on the 3447s.
[1]They have the small airhorn & flow about 575 cfm. The Edel 600 carbs have the same venturi & t/bore size, but with the larger 5" air horn flow about 600-625 cfm. If the engine can use the extra airflow, might be a benefit.
[2] If you remove the airhorns from the 3447 & Edel, I think you will find they interchange. So you could use The Ed top on the 3447 body for more airflow.
[3] I suspect the boosters will also interchange. You would need to check the height of the 'shelf' that the boosters sit on & compare between carbs, because this could affect float level.
Good luck.
GTX John.
Good luck.
I have had the 1405's worked on and should be fine. They can work on the 63's as a 63 car in C/SA I know has run 10.40's with them. Hope my new high compression 63 motor makes some hp close to his. I did run the big tops on the 3447's and seemed ok. Just seemed to idle better with the edelbrocks. Now my next question that I will ask everyone is if the 64 intake is better than the 63. This motor will have 518M heads, which are 64 heads and wonder if the 64 intake will work better. I'll ask and see what I get.
PM sent
I think any of the Carbs have plenty of Air flow
for these engines.
I never found much difference between HP on 3447
and 3705.
Once (You can Believe it or not) I unhooked the Secondaries and only
lost 3 tenths on the 3705.
PM sent
for these engines.
and 3705.
You have tried it all. You would think more than 3 tenths. Interesting. I lucked out. Broke one of my heads, but a friend who has decided not to build a stocker motor gave me a heck of a deal on his 518M's. Will have them checked in October when I have a chance to pick them up. If they don't pass inspection then I get my money back. Can't beat that. Racing is soooo much fun!
Some of the Replacement 518M are not very good.
I "think" the early ones. I am racing in Bakersfield Divisionals
and a couple of the top Max Wedge engine builder
will be there and I will see if they can tell me.
John,
Good call. A lot of wobbly nonsense around about having to use huge carbs to get good #s.
Wow that would be good to know and how to know if I would buy one. My friend may also have an original set, not the M's. Just have to see if they haven't been ruined. The real question is how does one determine if an M head is bad. Check the runner sizes or see what they flow? Or is it obvious? I could have the local cylinder head guy check them. Well, if you get a chance to find out anything let me know. Would greatly appreciate that. Thanks.
I believe it was determined by when they were cast.
i will try and find out this week.
When I raced the Max Wedges was before the
Replacement heads were available.
One thing that I found wasn’t very consistent between the various casting runs of 518M heads was the chamber volume.
Some were huge, some were smaller than spec right ootb.
I’ve also seen a few with fairly significant core shift, as well as very wavy valve cover rails.
I’ve seen a few with fairly significant core shift, as well as very wavy valve cover rails.
So in some ways the original 518's if not ruined for stock eliminator could be less of a problem. Everybody kept telling me 518M's were the real ticket. "Oh, they are better than the original 518"s they say. Maybe so if you get the right pair. So what is there to watch out for on the original heads? Other than if someone ruined them. Thanks for the post, I appreciate it.
