Hello all, Restoring a 1964 Fury, been reading tis forum for some time now, looks to be a wealth of knowledge and a great place to gain some.
1:40 PM
I could use a lead on purchasing a set of stage III heads for my 1964 Max Wedge motor, also need the original intake. Anyone know of or have a set for sale?
Mancini ….. Kramers ……may be sources you would want to check out, or posting Want Ads in the appropriate section. …..
Mopar 2 Ya !!
Welcome !!
John
Thank you. I've look through both these sites and a few others, great options for aftermarket head selections, but having a hard time finding original. I've toyed with the idea of aluminum heads from a performance view. My goal is to build as close to OEM as possible. The car was purchased with a Street Wedge, still not sure if the block is set up for Max Wedge, the block casting is 2406730, any idea if the conversion to a max is possible without pulling the head off and looking at the deck to see if it is machined for the larger exhaust valves?
Welcome from the central coast.
Welcome from WNY, that is One Fine '64, and don't be shy on Posting some More Pics !!!
Restoring a 1964 Furry​
We don't really get into the "Furry" stuff here... This might not be the right place for that sort of discussion.... :lol:
Good luck with your search for heads for your "Furry"
Welcome to FBBO from NorCal Sierras
maybe post a WTB thread in the appropriate classified section here
& browse look in the classifieds here too
maybe even use the search feature on every page 'top right'
to find stuff, sometime is helps
& I'd suggest reading the forum rules 1st too
good luck
Welcome from NY.
Just a tip: You may want to rethink your username choice.
(a good way to get tons of SPAM)
contact @Joeychgo
what engine is in this car? The block casting is 2406730-1, I pulled the valve covers last night and the casting numbers are 2406518-1. It has a single 4bbl carb, block and heads based of casting numbers = 426 Max Wedge, on the top right side of the block it's stamped 426. Is this a Max Wedge with the wrong intake?
