Misunderstood Mopar tech 400, Thermoquad etc.
...but there are verifiable reasons for a sbc 400 to be "second fiddled" that don't apply to a Mopar 400 or 360.
1- no 4 barrel version ever offered. Not true of the Mopar 400 and 360.
2- oddball heads that don't interchange. The Mopar 400 does have different heads, but they are no worse than 383 heads and do interchange.
I'm NOT a chevy scholar, but those are the two that I know.
I am a "knuckle dragger" when it comes to Chevy, but was the sbc 400 really a 400? I ask because my coworker back in the day had a 1972 Chevelle SS 396, but it was actually a "402".
The way I've understood it-
If you ordered a "400" in a 1972 truck- you got a 402 big block.
If you ordered a 400 in a 1972 car- you got a 400 small block.
Yes it was..SBC 400 came with a bigger bore but shorter rod than the 350. Like a Mopar 400, it had the biggest bore of that engine family (4.125 vs 4.0 for a 350).. the only reason GM kept calling the BB 402 a 396 in 70 was for marketing reasons because it was so popular, but they did eventually market it as 402 as my friends 71 Chevelle SS had it on the air cleaner. The change was to help offset the lower HP ratings. (He now travels the country authenticating SS's being sold).
Yep, the 400 sbc was 400. Used a longer stroke crank, short 400 ONLY rods, and completely different b/s than the 396/402. The 402 was just a factory +.030 396. It WAS labeled a 400 on trucks, but the 396 mystique kept that designation for a couple years on camaro and chevelle.
Yes it was..SBC 400 came with a bigger bore but shorter stroke than the 350. Like a Mopar 400, it had the biggest bore of that engine family (4.125 vs 4.0 for a 350).. the only reason GM kept calling the BB 402 a 396 in 70 was for marketing reasons because it was so popular, but they did eventually market it as 402 as my friends 71 Chevelle SS had it on the air cleaner. The change was to help offset the lower HP ratings. (He now travels the country authenticating SS's being sold).
Nope. 400 had a longer stroke and bigger bore than a 350. But some 400s were redone for racing (rpm) purposes with 327 or 350 cranks. (Steel cranks. 400s were cast, using spacer bearings, or just spacers).
The longer stroke 400 crank in a 350 block gets 383-388 inches.
Agree, other than the 400 crank stroke.
The 400 crank was a 3.750 ?
Yup.. my mistake, I put stroke instead of rod. I fixed it. Thanks for pointing it out for me.
