Reproduction build sheet
Put your info into a site I was given yesterday
XS29:
Dodge Charger
Unknown
2 Door Sports Hardtop
UOG: Unknown
Unknown
St. Louis, MO, USA
138237: Sequence number
E86: 440 cid 4 barrel V8 (High Performance) 375hp
D32: Heavy Duty Automatic Transmission
E87: Exterior Color
C6X: Trim - Charger, Vinyl Bucket Seats, Black
TX9: Int. Door Frames
A06: Build Date: October 06
023072: Order number
V1W: Full Vinyl Top, White
A01: Light Package
B51: Power Brakes
C21: Center Front Seat Cushion
C55: Bucket Seats
G36: OS Dual Racing Mirrors
G33: LH Remote Racing Mirror
H51: Air Conditioning with Heater
J25: 3 Speed Wipers
J45: Hood Tie Down Pins
L31: Hood/Fender Mounted Turn Signals
M21: Roof drip rail moldings
M25: Wide sill moldings
M31: Belt Moldings
N85: Tachometer
R22: AM Radio with 8 Track (10 Watts)
V6W: Longitudinal Stripes, White
26: 26in Radiator
END: End of Sales Codes
Thanks.. now the only problem is the mirror debate on what was factory on my car. Lol. I think the ones on it are "racing mirrors" as opposed to the stock ones on normal b bodies, but no one ever can tell me for sure.
Mirrors
XS29:
Dodge Charger
Unknown
UOG: Unknown
Unknown
St. Louis, MO, USA
E87: Exterior Color EB7
TX9: Int. Door Frames painted black
A06: Build Date: October 06 Scheduled Production date
A01: Light Package
B51: Power Brakes
C55: Bucket Seats
G36: OS Dual Racing Mirrors G31 right side (passenger’s) manual chrome mirror
G36 is the painted racing mirror introduced in March of 1970
G33: LH Remote Racing Mirror left outside remote control chrome mirror.
G35 is the chrome racing mirror and is not a valid code for 1970
J25: 3 Speed Wipers
M31: Belt Moldings
N85: Tachometer
26: 26in Radiator
Expand to see updates to decode.
So the ones on there should be correct. They just didn't paint the lh side one as it was a remote style, correct?
No. The decode was the polite way of saying the mirrors are wrong. The tag codes G31 and G33. There’s no G36 on the tag as shown in the decode.
G36 painted mirrors were not released until March. Your car was built in October; six months before they came out.
You data plate state inside remote mirror on the drivers side. That is not a remote mirror nor is it a factory mirror. Watch this video This charger has the dual sport mirrors that would have came on all B-bodies in 1970. They do not look anywhere close to the junk that is on your car.
Thanks for clarifying. I will have to start looking for some factory style ones
This a very touchy subject for many. I personally don't mind someone wanting a show display piece as long as its not ever represented as an original or anything of the sort. I don't know of any service that makes anything close to a spot on original (thank God). With that being said, if you want to make one for your vehicle (just for fun), here you go:
http://www.moparts.org/Tech/tech/logos/build-sheet69.pdf
In your browser, change the 69 to 70.
I'm not sure what that link is supposed to be to but whatever is there does not represent a 1969 broadcast sheet.
Hi, it is obvious that this questions has come up before but out of curiosity is there a source or service available to have a "lost" or "damaged" build sheet reproduced?
If you have the fender tag, the original window sticker, title and in physical possession of the car....what else is there you would need to provide in order to replace the build sheet?
1) I hope there is not a service that reproduces them. There' is enough fraud in the hobby the way it is without making provenance documents. But, I know fake sheets exist. I've seen them. They can be outed by.....
2) Broadcast sheet codes change during the model year for various reasons. Assembly numbers change, option codes change, parts numbers change. One would need to know pretty much every code and every related code for a car for that date/week time of the year in order to reconstruct a BS.
Like fender tags, BS have nuances that only show up with extensive research.
IF a sheet has codes not in effect with the corresponding SPD/VIN range, they are pretty easy to spot.
Faking documents like BS and tags can be done but it takes a boatload of research most people trying to make a quick buck won't do.
