Source for front disk brake positioners
Coelacanth
4:18 AM
Edmonton, Alberta, Canada
I let my original disk brake positioners soak in Evaporust then wire-brushed them mostly clean. I see the FSM recommends replacing these with a brake job, but they're not included in the hardware kit and I could not find them anywhere on RockAuto. Who has a source for these, and might my cleaned-up originals still do the job? Also, looking closely at these, the top two have a divot and not just flat. The FSM doesn't indicate which positioner goes towards the front and which towards the rear of the caliper. Any ideas?
#332-48846 in the Layson's catalog. You're welcome. Their $20 catalog has helped me sell so many parts for them. I should be on commission or at least get my $20 back. :rofl: :poke: :rofl:
@Rick@Laysons
The positioners should be placed as shown in the following image:
The positioners can be reused if they can be pried open a little to install with light tension. Carefully pry them apart and watch for any cracking in the bend area.
The positioner with the raised, or depressed, area is original or like an original and fits better over the caliper bolt rubber bushing. The other style will work okay though.
Thanks Vaanth. My positioners are in good shape, I already had to give them some subtle bending to match the shape of my divoted ones, as those were in the best condition and original shape. It's good to know it doesn't matter whether they're installed front or rear of the caliper.
That's a great photo, it closely matches this one I found earlier today on the forum:
From what I remember there is a TOP and BOTTOM - but it has been a while since I did my callipers.
Both positioner clips are mounted on what I'd call the top of the caliper; one to the front, one to the rear, as shown above in both images. The clips do indeed have a top and bottom side; each one has 2 little arms making 90-degree bends that mate with the flat surface machined into the caliper.
That said, the calipers are clocked forward on the rotor to about 10 o'clock (on driver side) so the front end could be called "bottom" and the rear end could be called "top". :)
