'68 Charger green interior paint
RT68440
9:30 AM
Akron, Ohio
I posted this in the interior section but thought I would post here as well.
I'm gathering all of the materials to freshen up the interior pieces for my Charger with dark green interior. I'm trying to get the paints figured out. I already have the suede paint for the dash and column from instrument specialties. I'm looking for the paint to do the bottoms of the doors and the headliner side retainers along the roof rail. I've been researching the paint codes that were originally used by PPG. Here's what I've learned so far:
Catawba green 43695 (gloss)
Catawba green 43721 (suede)
Velvet green 43137 (low gloss)
My question is the gloss level pertaining to the door bottoms and the roof rail trim. My doors were repainted all body color at one time so I don't know what the gloss level was originally for the bottoms and my roof rail trim looks pretty low sheen. I'm assuming that they were painted velvet green. Would the door bottoms be 43695 gloss or 43137 low gloss? Did any pieces actually get painted 43695 gloss? Seems like all of the interior painted pieces were suede or low gloss to keep down on glare
Inner door panels and the side headliner/roof garnish were gloss finish.
Suede finish on upper windshield garnish, dash, steering column & ashtray.
Defroster ducts, kick panels, upper A-pillar garnish, seatbelt anchor covers - all the plastic stuff - was molded in color, a satin-ish finish, and not an identical match.
I should add: I've restored green, burgundy, blue, and a couple with black (white & black and silver & black) - and with the colors, I usually buy 4 of the listed colors.
The color chart info for interiors is sometimes not the same color on the original items I'm repainting.
The suede finish goes on dry for the proper rough texture, if that makes sense.
I have a pint of the acrylic lacquer suede paint from instrument specialties for the dash, column and upper windshield. I also bought the dark green paint from herbs parts that I've sprayed all of the hard plastic parts with already. I have a quart of vinyl paint/dye that I bought from ABC Moparts that I'm going to do all of the dash pads, upper door pads and arm rests with to match the upper dash pad that they restored. The only thing that I really have left is the door bottoms and headliner side trim. My headliner side trim is original but seems dull. I wasn't sure how shiny it's supposed to be and I know that the original owner was a smoker, so I'm assuming that some of the dullness is from cigarette smoke and age. So far all of the different paints are slightly different in shade and sheen which I like because it looks correct. Not a fan of an interior that looks like it was all installed and then sprayed with a single color over everything
