1966 Dodge Coronet forgot where some wires go on dash harness
Gscyrkel
6:31 AM
Virginia
First photo here is plugged in the wires to the ignition and i think I plugged it in right but there's an extra prong not connected. This doesnt seem right is it?
Ive somehow done the same thing for the wiper switch there's an extra prong not connected this also doesn't seem right
This is the purple cable and purple with stripe wire that starts at the connector behind the drivers side kick panel. I think I recall the two prong connector plugged into the two prongs on the steering column but I dont have any idea where the single prong went.
And lastly these pink and white wires these are at the end of the harness near the multi connector for the steering column. The white wire comes off that connector pink comes from somewhere else. I appreciate any help in this dont want to do this wrong and mess something help. Thank you
Last pink and white are for the brake lamp switch.
The wiper needs all prongs with a wire. How about that single wire in the carpet?
The two prong connector on the carpet is for the reverse lamp switch.
