FOR SALE mopar 440 solid roller cam
stage3
1:06 PM
california
Feedback: 5 / 0 / 0
comp cams solid roller for all RB motors. specs r in the pic's.
395.00 shipped to the lower 48 ONLY.
Just a note...seeing as you state this is for all RB motors, then it will be fine for ALL RB & LB engines; with one exception: It does not have the same lobe profile as the RB 426 Hemi Camshaft - therefore it will not work in a RB 426 Hemi engine. CHEERS! AL :)
P.S. I fully realize that you did not state it will work in a 426 RB engine, but RB/LB WEDGE engines are all compatible. Again, the 426 Hemi Engine Camshaft is different. Piston-to-valve clearance is mandatory check, after installation...Thanks! AL
Just a note...seeing as you state this is for all RB motors, then it will be fine for ALL RB & LB engines; with one exception: It does not have the same lobe profile as the 426 Hemi camshaft - therefore it will not work in a RB Hemi engine. CHEERS! AL :)
mopar 440 solid roller cam​
