Hard Lesson in Front Brake Drums...
Rob'68Net
5:46 AM
Johnstown, Pa
So...1966 Dodge Coroner 440. !0" front brake drums. Decided to do a wheel swap and change to right hand thread lugs, and that's where the fun began. Not realizing the wheel studs were swedged, I separated the front hub from the drum (I know bad idea)..and bent the brake drum in the process. Seeing as how that wasn't good enough I made mistake # 2 of trying to remove one of the wheel studs out of the hub by pushing from front to back, doing yet more damage by pushing the enlarged wheel stud through. I was able to obtain an aftermarket Raybestos front drum, but of course it doesn't come with a hub. At this point I said the hell with going through the trouble of changing to right hand thread studs. I have come to discover that even if my existing front hub is salvageable. left hand thread wheel studs are virtually nonexistent. What are your thoughts, should I try to locate another left threaded front wheel hub, or try to get a complete hub/drum assembly that has never been separated ? Side note, the new Raybestos drum has the same inside drum dimensions, but outside of drum is slightly different in design (no groove for the spring around the drum.) Any input would be greatly appreciated. Thanks in advance !
10" drum assembly's shouldn't be to hard to find in LH or RH. If you find one, I suggest that you replace the the front bearing, races, and seals. I don't know if I have any 10" stuff laying around, but will check tomorrow as today is almost shot. Once you have bent a drum, it's toast.
I'd appreciate it...
Yeah I considered getting a RH drum assembly, but that still would leave me with the left rear being LH thread studs
I didn't think it needed to be said but, knock em out and put rightys in.
That's the easy part
The rear wheel studs are a simple swap.
Throw away your damaged front drum parts.
