67 Coronet blinkers
vinny719
2:53 PM
New York
When I turn on my blinkers either left or right both rear blinkers flash one indicator on the dah blinks the left front blinker gets power on and off in assuming if the bulb was good it would flash the right front blinker gets no power I’m hoping it’s a ground no interior lights, headlights work tail light work brake lights work anyone help me out in the right direction thanks
I have had a few cases on any year that the bulb is wrong or defective. Won't hurt to check it.
A ground second guess.
replace/repair turn signal. Had the same issue with my 67 Coronet...
Does the 4 way emergency flashers work?
so if it has 4 way flashers is there a flasher for both the signals and the 4 ways
Yes. My point is if the switch is possibly on the rear turn signals may not function correctly along with the front.
I do have a 4 way flasher switch How would I test the 4 way flasher
Yes and there’s no difference when I turn on the single either left or right the rear blinkers flash like the 4 ways are on
