Questions about front shocks.
Gene D
New Member
11:00 PM
Indiana
I Inherited my father's 1970 charger. I am changing the front shocks and suspension components because it sat for some time.
I recently bought bilstein 55-r082 shocks for the front as recommended by others. The problem I'm having is the shocks when installed do not let the upper control arm rest on the bump stops. I would say its off by about atleast 3/4". Removing the shocks, lets it rest on the bump stops. Is this typical? Also, torsion bar is loosened at the moment. Any reason why this would be the case? The cars has been kept stock all it's life.
Why would you want the control arms to rest on the bump stops? Bump stops are for excessive travel, as hitting a pot hole or severe change vertically on the road surface. Sounds like you have several other issues to deal with. Torsion bars shouldn't be loose. Someone else here with more knowledge about front suspension will jump in.
Sounds like the suspension is at full droop from being in the air. To me, normal stuff on the shock. When you let it down, put the bushing/washer/nut on and cinch them down. Did you loosen the bar up? It should still have some load on it even when up in the air. Maybe have dead bars or the lower control arm bushing is toast. Like this one from the 72 Challenger I'm working on.
If you are rebuilding the front end why not replace the portion bars as well. They do get tired after supporting the car after 55 years.
The Challenger is getting upgraded big time. Along with the usual front end stuff.
I loosened the torsion bar to replace the upper control arms. I'll take a closer look at the lower control arms to see if there is excessive wear. Thank you for the replies.
The UCA doesn't "sit" on the bump stop. If you loosened the torsion bars, they should be raised again to alignment specs
Gene,
I would say you have the wrong shocks. If the shock bottoms out/goes solid before the bump stop takes the hit, why bother to have bump stops????
If the car is on jackstands or a car lift, yes...the upper control arms should droop enough to rest on these bumpstops:
If you have tubular UCAs....
If the suspension is at full droop and the upper control arm does not touch the bump stop....yeah, the shocks are too short.
People advise Bilstein shocks but they need to be specific. The RCD version of Bilsteins are the correct ones. I'm pretty sure RCD stands for Race Car Dynamics. They are available through Firm Feel Inc.
Regarding your "loose torsion bar", if the car is up in the air with the suspension unloaded, the torsion bar has no tension on it and may move a little.
Cheers and welcome to the forum.
I just put a set of these on and have the same thing, the front shocks are too short and won’t allow full droop. I have the RCD 55-R082s.
I just called Kanter, (used to be PST) and they are going to contact the manufacturer after confirming I have the right part number. He agreed it’s not right. Are you able to measure one? Both of mine are installed and would like to send them the exact difference in length.
I should of mentioned earlier that it is sitting on blocks at the moment so the suspension is at full droop. I ordered them through Kanter recently. The bilstein measure 15 3/4 from center of hole to top of first rubber bushing. The original shocks measure close to 16 1/2.
I should have mentioned earlier that it is sitting on blocks at the moment so the suspension is at full droop. I ordered them through Kanter recently. The bilstein measure 15 3/4 from center of hole to top of first rubber bushing. The original shocks measure close to 16 1/2.
I just heard back from Kanter they are contacting the supplier about it. Of course they claim there has never been an issue like this before.
If my memory is correct, mine were a little short when the suspension was at full droop. I got the stud in the hole, so once I let it down on the wheels, it poked through the rest of the way. From there, put the grommet, washer, nut on then cinched it down. To me, normal stuff. Back ones the same way when the springs are at droop. A little short. Not the end of the world since it doesn't stay in those positions when driving.
Well, you sure don't want the shock to either bottom out or top out before the suspension itself does. That puts undue stress on the guts of the shock absorber.
When I worked on the wagon, the shock was just under an inch before being fully seated in the hole. That was before I put the bumper in. I'll have a look at the Challenger to see if any of that changes.
Apparently the part numbers are correct and these shocks are within spec as far as RCD is concerned. On the face of it I didn’t care for them being short either but I don’t see what could really go wrong under normal use. I can say that it rides MUCH better than the bang, bang, bang, of the KYBs that were on there. Many thanks to the members that wrote about it here.
My experience as well.
I'll post some pics tomorrow when I get further along on the 72 Challenger I'm currently working on. I had to whittle on the bump stop bracket on the frame rail to get some room for the Bilstein shock to clear. It has a larger body than the KYB's that were in there. Once I did that and installed the upper control arm bumper, the shock was roughly 3/4" from the tower to the stud bushing at full droop. Without the bumper, it would have been easily double that. But like I said earlier, SOSDD[ same old s..t different day]. And as everyone can see, the picture is off 90* cc.
