Bipolar fuel gauge
OzCharger69
3:50 AM
Australia
So the other week my fuel gauge was showing that I was on empty when I knew I had half a tank. I have Dakota digital gauges and you calibrate the gauge at 1/3 2/3 and full tank. I checked all connections and the earths all were fine. I emptied the tank and started filling up to recalibrate but the sender sat at 80ohms whether the tank was full or empty. So I thought the sender was dead or the float was punctured or stuck.
Today while cruising the fuel gauge came back to life. I emptied the tank to confirm that it was working well across the range and it was.
Any idea what could have caused this?
Pic of the little **** poking her nose
I am looking at the Dakota Digital Dash and have been doing the research on the fuel gauge because I want to know how to set it up. There is a section in the installation manual about a specific way to ground the fuel gauge. Did you follow that? Also did you try changing to one of the pre programmed settings to see if changed any response?
I've had the Dakota gauges for 3 years and I calibrated the fuel gauge 3 years ago and never missed a beat. The issue I have is from the sender.
Basically you pair the gauges to the Dakota app on your phone. Start the calibration with an empty tank, fill the tank a third at a time while telling the app when it is 1/3 then 2/3 and then full. It is extremely accurate.
And you have tried a new sending unit?
Not yet, I pulled it out yesterday and checked it's ohm range and working perfectly
Have you tried running a new piece of wire directly between the gauge and the sender unit?
It is possible that the blue wire is damaged and is shorting under the spare tyre or rubbing on the sill covers.....if you have the original loom in the car.
It's worth checking, as it will never cure itself.
"Bipolar fuel gauge"​
You need to put a dose of Abilify in the tank !​
That's a good point and I ran a new shielded wire a few years ago. That's the first thing I checked and there are no breaks in the wire.
I bit the bullet and bought a new sender, I have little hope that it will fix the issue
