Alternator suggestions. 165 Amp?
l69white
1:38 PM
New Mexico
Hello B-Body friends. I'm new to the forum and did some serching but can't find the information I'm looking for. I'm trying to decide what alternator to purchase for my 1968 Charger build. I'm also looking for information on brackets needed for mounting of any suggestions. If possible I would like to stay with single V belt set up I currently have. Specs. 440 to 512 Stroker, TKX 5 Speed, Sniper 2 EFI, in tank fuel pump, Griffin Rad. with dual electric fans, Dakota Digital dash, Hyper Spark ignition system and finally Vintage Air AC system. I used an online amprage calculator and it recommend 152 Amps. Thank you all for any advice and help.
I would be very curious how you came up with 152 amps. That seems very high. Other than the fan, what draws more than 10 amps?
Dadsbee ,
Helicopters need 200 - 300 Amps for ground starting , but once in flight , they require generally 120 amps for standard operations….
Yours , Craig….
So sounds like marketing slant to me.
If you list specifically what the rated amperage draw is on your major components we can help you decide what you need.
Remember that the centrifugal devices (like the water pump and fan) amp draws varies with voltage. Centrifugal devices in general follow affinity laws which states that flow is the square of the speed and horsepower is the square of the flow or cube of the speed. The speed of these devices is proportional to the applied voltage. Need to keep this in mind when sizing your charging system.
In addition, when sizing these larger charging systems, cable sizing and cable lugs selection is critical, along with proper fusing.
Dadsbee ,
Yours , Craig….
Must be a big f'n helicopter. Running on mags, once they start they need nothing but enough power to run the radios and nav aids.
Ok, so I don't need 152 Amps. Good news. What do y'all suggest then? Would the one attached be sufficient then?
That makes sense. I will assess the amp draw for my components and go from there. Thank you.
My rule#1 for buying an alternator is if I can't get an amp versus rpm curve I don't buy it. The amperage rating can be VERY deceptive, especially at low rpm.
I'm clearly out of my depth on this part of my build. Lol. I'll figure it out eventually. Thank you all for the help.
Give this a quick read. Its pretty simple - at low rpms, the alternator puts out a lot less amps than at higher rpms. The rated alternator amps gives very little information on how many amps the alternator will actually put out at the rpms where it matters. Quality alternators do better at low rpms than cheap ones.
Quality alternator vendors will provide this information, sometimes you ave to ask for it.
call John at Powermaster. They can help. I run the biggest on they. Are and it bolts right in with stock brackets. Think max is 175 amp
Run what ever you want, just remember that no matter how big it is, it will only put out the amperage needed PROVIDED THAT THINGS ARE WIRED CORRECTLY. Jesus, I think Bob jumped into me like some horror movie...
I thought 100 amps was when you needed two belts to drive it. I replaced the stock unit on my camper van, and do not know what amperage it is. Somewhere between 55 and 75 I would guess. On the boat where lots of stuff is running the alternator is 55 amps. I think it is advisable to run a smart regulator outside the alternator for larger amps.
I cannot think of any need for more than 75 amps. And follow the advice above for charging rates.
the stock late 60's Mopar alternators were only what like 45 amps? I kept that in mind when selecting a new alternator for my car and installing Vintage Air A/C and no stereo system. I went with a Powermaster 70A 3 wire alternator and it gives plenty of juice with no bad behavior at all.
30 amps was the lowest.
Here is a list from the 1970 parts book with amp ratings. Notice it has D which is Imperial with the maximum of available electrical options and the max amp output is 60. That's it.
Your alternator amperage does not need to match the starter amperage draw. It needs to power the things runnning as you are going down the road at a cruising RPM. So not even the cooling fans. That's why batteries are rated for reserve capacity. The battery will run some of this at idle, then it will recharge going down the road.
If you voltage regulator goes wide open now you have a constant 165 amps going through your wiring harness. Eve see photo of cars on fire by the side of the road?
what I'm still not clear on is what types of applications would require a 100+ amp alternator? I was thinking if you're running a high wattage stereo system, correct?
Boats with a lot of electrical stuff running. We have a regular fridge, plus a beer fridge, an auto pilot and navigation gear.
And we use a 55 amp alternator. But bigger boats have even more stuff. We run the engine while using the anchor winch.
I was just reading my book about 12 volt systems. Worth studying, but a bit scary. The part about operating temperature.
