Factory rear speaker mounting
vegiguy
1:28 PM
Newton, Kansas
How was the original 5X7" rear deck speaker mounted in '71-74 b-bodies? The holes for it look pretty small so I can't tell if they were screwed in from below with #8 sheet metal screws or attached with tiny (about #6) machine screws and nuts, or some other way that is less obvious. I want to add one of these speakers to my car so any help would be appreciated.
I think that opening was for the rear window defroster. Not a speaker opening, although many use it for a speaker.
I just got done making a separate post on that topic last week. We established that the right (passenger side) opening in the package shelf was the one for the defroster and the left (driver's side), smaller opening was for the optional 5X7" speaker.
I installed U nuts on panel and used screws to attach the speaker from underside. That will save from remove the package tray. On this case I went for the practical instead correctnes, which I think is install the screw from top side.
( about the single or dual speakers setup on rear... there is still a mistery about that based on some diagrams LOL )
I assume your year is the same...here's a survivor 71 GTX. Notice the speaker is mounted from below.
I don't know what the advantage of using U-nuts is as #8 sheetmetal screws thread right in the holes that are there as long as they haven't been tampered with.
Re dual speakers: I doubt this was an option, at least in '73, because I can't find any dual rear speakers diagrams for B-bodies in my factory service manual; also, one would have to be 5X7" and the other 6X9" if you go by the size of the openings (at least in my car) which seems unlikely.
It looks like a previous owner of my car had tried to install a 6X9" speaker on the left side of my car's package shelf (I assume to match one they had installed on the right side) - even though the opening is for a 5X7" speaker - because there are screw hole drilled for that size speaker. The problem with doing that is that the opening really isn't big enough for that large of a speaker, plus the holes have to go outside of the recess in the shelf so the screw heads stick up which makes it so the package tray doesn't lay down right.
Unfortunately it looks like B-bodies from the early 70's never got very good stereo systems compared to say E-bodies that you could get with I believe something like four or five speakers.
old picture, don't have one on hand now. no separate washer, the shoulder is part of the screw
It looks like the same type of screw GM used to mount the inner door handle bezels on 2nd gen Camaros and Firebirds.
I know I am answering an old thread, but I have a 67 GTX with the rear speaker fader switch but the rear speaker was missing. On top of the package tray, the speaker cut out is recessed approx a 1/4" or so. Is it possible that the speaker sits in there flush? And just put the screws down into the holes and tighten. otherwise, why the recess?
Do you have any pics of how they routed the rear speaker wires or special clip that held them to the car?
I am deer hunting on my farm in PA. But, the wire was routed down the driver side rear seat and along the floor close to the door. There should be a long metal cover that forms a tunnel going down both sides of the inside of the car for the wires to run thru.
