Dibbons
- 1:05 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
Some time ago sent my gauge cluster away to have the ammeter converted to a voltage meter. After installation (with new voltage limiter) everything worked OK. This 1972 Satellite Sebring Plus was "stored" for quite some time while doing an engine swap (318 to 340). Now it's running again with the 340 but none of the gauges work: oil pressure, fuel, coolant (except for the speedo/odometer do function).
First step is finding which fuse feeds the limiter (I ask here only because i'm not the greatest at reading wiring diagrams). Then I'll check for ground, and if necessary pull out the entire instrument cluster (not fun). Thank you.
Good video on the subject I just referenced:
