Help id 2 ring & pinion sets
HEMI-ITIS
STREETER on LI
5:40 PM
Long Island,New York
I am going though some parts in the garage for a sell off.Need some help to ID 2 gear sets.Thanks for lookin'
Look like Richmond Dana 60 gears to me....
Al. The set in the foam case are 5.38's I counted 43 teeth on the ring gear and 8 teeth on the pinion. I bet that they came from Jimmi Virgonia.
What are you trying to ID? The brand, ratio or what they are for? And I only count 41 teeth on the ring in the box....a 5.13 gear. The stenciling in on the pinion is for the pinion depth setting and the BL on the ring is for back lash...being .008" clearance.
Poppa j,you'd loose that bet:icon_hang:Cranky,trying to find ratio and what the other set fits.One set are the dana 5:13's that came out of my car when the 4:10's went in,and I'm not sure of the other set.So which are the 5:13's?
The ones in the styro box are 5.13's. 43 teeth on the ring and 8 on the pinion. Finding the ratio is easy. Just count the teeth on the ring and divide them by the teeth on the pinion. Do the other pinions look like the one in the styro box in pic #2?
the set marked 7327/8327 is a richmond 4.88 gear for Dana 60, the 7330/8330 is a richmond 5.13 also for Dana 60
Thanks fellas,got a swap meet coming up and will also post em up:icon_salut::hatwave:
