Mr.SpeedFreak
- 12:26 PM
- Jan 29, 2013
- Southern Oregon
Hey guys, I'm working a deal right now to pick up a used procharger from a friend here locally and just had a few questions if anyone has experience/ secondhand knowledge of running one on a mopar.
I know the Supercharger Store down in Arizona has mounting kits and stuff, but how would adding the procharger effect my accessory drive setup as it is now (Factory pulleys, alt, water pump, power steering)? I would probably end up running a cog belt if everything would still be compatible
Also are there any air intake options other than the cone filter sticking out the back of the procharger sitting right on top of the header? I'll have an intercooler I can run front mount, but still not crazy about sucking that hot air straight off the header.. considered doing an aluminum heat shield for the bottom of the filter if it's worth any kind of gain on lower IAT's.
Is there any way to run a pcv or some other check valve in the power brake booster line to work with a supercharged engine? I know that's how some of the turbo guys do it but not sure with a procharger
I know there's a few guys on here running them so any experience you could share would be awesome
ccasion14:
ccasion14:
