I've built several 383 strokers 3.75" {440 crank ground to B block specs}
3.95" {offset ground 440 crank with 2.20" Chevy rods}
4.15" a couple 0.040"/4.290" bore 383/479ci
4.25" most issues with clearance & custom parts needed, no big deal thou
I haven't had any block failures,
have the crankshaft radius machined down to 7.125" or less
lighter crank, makes balancing somewhat easier & block clearance better
I also use a block girdle, good oil pump & pan etc.
use good rods, make sure it's line honed/bored straight etc.
have someone who "actually" knows Mopars do the machining,
not the local yokel, unless he knows his stuff
But
the 383 has "allegedly" the weakest of the B-series/Low deck mains/webbing,
the 400 has strongest mains & webbing, in stock form
the 383 is "allegedly" slightly stronger than the 440 mains, smaller line bore/surface area, less webbing area to break
I have a stroker using my OE #'s matching block,
but I don't realty worry about #'s matching stuff really,
I haven't ever broke a 383 block either....
good luck what ever you decide to do
