FOR SALE 4 speed transmission case and tail shaft
67RT
7:14 PM
Akron,Ohio
Feedback: 1 / 0 / 0
What you see is what you get. I believe this to be from an 18 spline trans. I have another complete trans that has similar numbers but no VIN. Not sure what its worth.We will start the bidding at 30
0 plus the ride or make an offer plus the ride.
Not that it makes any difference to the case, but that is a 73 trans, and 18 splines ended in72.
the tail shaft is a 73 ? or both pieces ? these are parts that I inherited with my 67. I have zero use for them.
The tail housing is 1970 or later due to the two shifter mounts. The main case has a 3 as the first digit of the vin stamping which is the model year. Also the 4203 is the 10,000 day calendar date which is Jan. 29. 1973.
Thank you for you help. Like I stated above, I have an 18 spline with no Vin that has the same tail shaft, so i assumed it to be the same. And I am always learning about assumptions. Name your price men.
I was asking 300 due to recent developments offers will now be taken. I now see that when posting the pictures it chopped up the post, it looks like I am asking 30. Not sure what a fair market value is but I am entertaining offers.
I’d be interested in the tailshaft housing if you’d separate them
tail shaft housing is sold.
main case housing is still available. 100 bucks plus the ride.
