FOR SALE Edelbrock victor MW bare heads
Moparmatt72
6:50 PM
Nampa, Idaho
Feedback: 1 / 0 / 0
Located in Nampa Idaho
Selling off my 77939 bare max wedge heads, they have been CNC ported by cncport.com, they used these heads for the program. Asking $2200 plus shipping. Heads new are about $1300 and the CNC is $1400.
20200703_144220.jpg 20200703_144229.jpg 20200703_144326.jpg 20200703_144334.jpg 20200703_144345.jpg Screenshot_20200619-121747_Drive.jpg
What numbers did it flow? its kinda hard to read the chart, Valves included? any rocker arms, also what year did you buy the heads, thank you.
Here is a better pic of the head flow with the CNC program. No valves or rockers its bare, they use to offer these like this so you can put any valves you wanted. I bought them back in 2012. Don't think you can buy these like this now, current price with just bare with valves is $799.50.
Bump, seats are cut for 2.25" intake valves.
Victor Max Wedge head with 75cc chamber size, 290cc port size, 2.200"/1.810" valve size
Intake ports are machined to match Max Wedge intake manifolds for B and RB competition big-block Chryslers Intake ports are raised .650", exhaust ports are raised .250" for improved flow The intake flange is extended .950" to eliminate the need for intake spacer plates Standard 15-degree valve angles with 290cc intake and 100cc exhaust ports Exhaust flange is extended .300" from stock (same as Mopar Stage 6) featuring dry exhaust bolt holes with Helicoil® thread inserts Raised valve cover rails and dual quench 75cc combustion chambers Sold without springs or retainers; use recommended springs to match your cam
