Paul_G
- 1:11 AM
- Dec 24, 2013
- Surprise, Arizona
I am rebuilding a 383. The crank still has STD bearings in it. There is some scoring on the journals. Lines I can feel with my finger nail. The rear one is the worst. I went over them with some 1000 grit paper wetted with WD40. They came out pretty good except the rear one, it still worries me.
A friend has a 383 crank that's been standing in his shop for many years. It was cut 10/10 installed in an engine and never used. He pulled it, put white grease on the bearings and journals, taped the bearings in place and it has been standing ever since. I bought it. The grease has turned to hard paste on the bearings, the masking tape has turned hard and the glue is stuck to the bearings.
The crank is good, journals look nice. One main bearing fell off and he cant find it. So need a set of new main bearings since I don't see them sold separately.
The grease is caked to the bearing surface on all the bearings. it wont come off just rubbing with a rag. Is it advisable to soak the rod bearings in WD40, brake cleaner, or gasoline to loosen the hard caked grease?
