Radiator cap
Data Plate
9:43 PM
New York
I have a Stant SP-9 7lbs lev r vent cap on my 69 charger RT 440 is that the correct cap?
No, on a stock radiator it should be a 16lb. cap.
Not correct as far as originality but it should be fine. The pressure just raises the boiling point of the coolant. Having overheating issues?
Richard has the correct small rivet '69 and prior caps available now. www.restorationpartsandmaterials.com
I think those lower lb caps are designed for aluminum radiators.
Damn that high pressure!...just kidding, that does suck. Hopefully it didn't drench your carpet too bad
Just a slight seep. Enough to haze the glass inside. I'm not a fan of stop leak but I might try that first.
Tie the hoses together now before it gets worse! I'd pull the box and replace the core before i dump that mess in there, that stuff wreaks havoc wherever it decides to clump together
Started the car today first time in 30 years ran pretty good. I put a 185 thermostat in it and its running at about 200 degrees which i thought was kinda high but thats at a idle i didn't take it for a ride yet.
200 high? No way....240 is high!
200 is not going to do any damage to your vehicle. However, you might get a little sticky sitting in the car on hot days. That's why a lot of owners like to run as close to 180 as possible. It's more a secure feeling and comfort thing than a requirement. :)
200 would make me worry, for sure. I like to see the temp w/in 10° over the thermostat, maybe 195° w/AC on in the summer in the swamp w/a 180 T-stat
I also know that beyond a point, detonation can occur, maybe by hot spotting a cylinder head, or just general temperature across the board being higher. It seems like my lifetime of experience is that old school big blocks run better at 180 than 200. New tech with new engines and new materials are made, designed to run hotter, old school engines not so much. JMO
Yeah, maybe that's just me, but 200 up would really have me anxious.
