Are 1967 fender ridge trim peices a 1/8 inche longer then 1966?
Breakin8
2:04 PM
lewisburg pa
Just a question. If so I could use a good pair of 1967 fender ridge trims.
Thanks
The only difference I know of it that the front fender end pieces were replaced by fender mounted turn signal spears in 67. I believe all the rest of the ridge trim is the same lengths for 66 and 67.
Mark
both front fender top pieces are different from 66 to 67...the long one and the short one
Bryan
What exactly are you looking? The front fender upper molding? The long section for 67? Or? And what condition? I may have may an extra set but needs to be refinished.
