56/71 Chopped Bug..71 Chebby Chopped Van
About this Mopar:
Two my Late Brother built.....the Bug was a seriously bad actor...56 oval chopped to 7" windshield, door posts kicked a la chop Merc, laid on 71 pan for IRS. beam front end pitched for chrome moly control arms, heim located w/ Spax coil overs and a Mitchell turn & a half loc-loc rack...suspension located in kustom fab square tube subframe tha bolted in over pan head and to cowl box...all fabbed by Willi Stryker....4 corner cross drilled discs, 911 5 speed, a 2150 with Webers...and a sweet little exhast with two tubeso out of extractor going 180 degrees to Treuhaft mufflers tucked under axles and exiting under running board just ahead of rear wheels.
Slider on the van worked, dash had to be cut down, windshield was 14"...roofline less than 6 ft
Item information
Category
FBBO Member Photo Garage
Added by
Bladecutter
Views
1,820
Comments
1
Last update
More from Bladecutter
  • Three from one
    Santini on blue glass, Brancusi on antique bronze boat prop, baby bird on copper......all three...
  • 2015 Aluminations Ensemble
    Aluminations propeller metal sculpture(aluminum alloy) Mostly hand carved....smaller pieces are...
  • 1963 Howard 500
    Total Testosterone here...# 14 of 17 built description is in for sale forum....this pup...
  • 1970 deTomaso Mangusta
    My "Goose"....pic vin 1980 # "Huns" Memorial Poker run in Sonoita, AZ, May 31st.....the bikers...
  • 1968 Dodge Coronet(post) 440(trim)
    1987 S.R. cali bummer 318 wuz rollover......MK V Linkin wuz a 2 1/2 month was a strip...
