1969 Roadrunner 383
Just some pictures of before and after of the roadrunner. These pictures are a little bit of the history or the bird returning to the road.
About this Mopar:
Very solid Roadrunner to start with. Floors solid, roof, and the rest of the body was in great shape. Only needed a patch panel at the rear wheel on the driver side. Only a lower quarter panel was used. This is the First time I have undertaken something of this magnitude. Let me know what you think of my progress. I tried to stay as original as possible and even took the engine back to its OE look. Although without a fender tag it is hard to say what this car was actually equipped with.
Comments
Thanks guys.. I'm almost done with the only thing left are the decals. And i think the blower motor resistor took a crap on me. Other than that its pretty much ready to roll to the alignment shop. Will probably end up putting a new steering gear in it. Due to excessive play in the wheel.
Great job and glad to see another runner come alive....Good luck and remember that " speeding is only speeding when you get caught"......
Having issues with that piece of crap Edelbrock carburetor. I cannot get it tuned to save my life. Doesn't idle well and at higher rpms it seems to sputter. I think I'm going to have to change carbs. This thing was like brand new but I picked it up used. The warmer the car gets the shittier it runs.
Had the same problem....put a 750 DP Holley...it is now fine!....after years of fu#klng with the "AVS"
We left it as it was. The engine and the engine bay were not touched as this is a driver and we werent going to pull the engine to paint it. However never say never. :)
Had to end up pulling the engine and trans. Something popped in the transmission when I put it in reverse. Then it felt like the brakes were dragging. Ended up getting a Hughes Performance transmission and a B&M Torque Converter. And since I pulled the engine and trans together I will go through the engine and repair and replace all of the gaskets. The rear seal was leaking anyhow so this was a great opportunity to fix the small but annoying leaks at one time.
That's a great looking Road Runner and a nice build set of pictures. Any updates on your non-carb choice and how it's working out for you? :thumbsup:
Installed the Holley Sniper on the GTX and one one the Road Runner. I will tell you the GTX had an o2 sensor go bad and I had it hooked up to the acc side of the ignition. I learned fast to not do that. On the RoadRunner have had no issues what so ever. Other than burned a couple plug wires when we added headers. OOps.. replaced them with Taylor SST wires and no problems since then. But If you want a car that acts like a modern car I would go with EFI, as soon as I can afford it I will be buying one for the Dart as soon as I can get some glass back into it and shoehorn the 440 into it.
Item information
Category
FBBO Member Photo Garage
Added by
BeepBeepRR
Views
4,644
Comments
18
Last update
Rating
5.00 star(s) 7 ratings
More from BeepBeepRR
Share this item
